Old 09-25-2009, 01:29 PM
patrickt patrickt is offline
Originally Posted by Excaliber View Post
Perhaps on my NEXT engine I will be asking myself more about cylinder filling as it relates to compression ratio,cam profile, port velocity vs flow numbers, idle speed rpm and how all that relates to initial timing, carb selections and finally,,, the STARTER! Not to mention counting the teeth on the dang flywheel.
For now, just bolt the right flywheel back on there and don't forget to use a little LocTite so it doesn't fall off.
