Old 09-26-2009, 05:21 PM
EarlsflyinCobra's Avatar
EarlsflyinCobra EarlsflyinCobra is offline
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default Need help form a FORD wiring expert, PLEASEEEE!!!!
As stated in this thread....http://clubcobra.com/forums/showthread.php?t=99843.... I tried several times to no avail!
Upon reviewing my wiring I have found a couple of things that I am not sure about and will try to explain simply so they can be analized.....
I have an MSD dizzy and the plug has 6 wires in it....they are as follows;
1.....PIP.....which I have hooked to the Grey/White Crank Input #2 of the MT Unit
2.....SPOUT...which I have hooked to the Blue/Grey Output #0 of the MT unit
3.....Start....which I have hooked to the Pink Coil wire coming from fuse block
4......Run.....which is not hooked to anything
5.....Coil....which is hooked to the White wire coming from the HI-6 Ignition box
6.....IGN GI......which is hooked to Ground
Does this sound right to any of you FORD/MT Experts???? Should the RUN wire not be used?????
I am wondering if #4 should be hooked up, and if #3 and #5 should be reversed?
Safe Flyin, errrrr Drivin, Earl
