Old 09-26-2009, 06:33 PM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
Earl --
OK, so lets start ( or try to) --
The MSD distributor if it is for an 86-93 5.0 calibration will run with the MSD BOX disconnected from the system, and the regular coil wires hooked to the coil.
1.-What harness are you running /using (Stock ford - Kwik, Ford Racing Etc )
2.- what computer A9L, A9M -- X3mu >?
3. list connections to car and where they go
4.are you running a check engine light<>?
5. How is your fuel pump being run >?
6. When you turn on the ACC (pre-start) do you see the CL and hear the fuel pump prime >?
