Old 09-28-2009, 07:05 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I have a KC 408 that I have in my Coupe and you can do two things fairly easily. One is replace the motor mounts with another set that Bryan has and if you do you may want to go with a different oil pan designed for road racing maybe a Canton that is only 6 1/2" in depth. The other is the simplist and cheapest and that is to go with a DROP BASE air cleaner if you are running a carb. On the FI stuff I really don't know but others have had the FI setup.
Clois
"Let's roll"
"Be part of Something Good
