Old 09-28-2009, 07:34 AM
charles roybal's Avatar
charles roybal charles roybal is offline
Cobra Make, Engine: FRR MKIII 408w
Default here one
For Sale FFR AC Cobra Shelby
________________________________________
This car is just stunning, it took me 2.5 years to build it, make it a beautiful Cobra and a perfect handling machine.
® Charcoal with black stripes
® Custom paint by New Direction Autoworks ($6000 3 years ago)
® Custom Made Halibrand style rims(TEAM III by North Racecars): 17” x 8.0" Front, 17” x 10.5” Rear
® Automoter Vintage gauge set assembly
® Under dash filler panel by Mikes Cobra
® 3 link deluxe rear suspension package
® Coil over shocks at the 4 corners
® Complete Sway Bars system (front and rear) from Vintage Performance Motorcars
® Hubs converted to 5 lugs
® 3.73 final drive ratio (FDR)
® 4 wheels disk braking system: Hawk’s HPS pads + Wilwood brake proportioning valve
® Comes with a soft top. The best top you can buy for the FFR AC Cobra– from Whitby Motorcars
® Custom made waterproof cover
® Custom made Cobra door panels by Herb’s
® All around Russel braided brake lines
® Adjustable brake pushrod (Breeze Automotive)
® New King Cobra clutch kit
® Rebuilt 8.8 rear axle with new 3.73:1 gearing (done by a DTS drive train specialist)
® Bump steer kit
® Solid aluminum offset rack mounting kit from Breeze Automotive
® New heavy duty Ford Mustang motor mounts
® New HEIDT’s hot rod shop power steering valve
The car also comes with a heater inside the cockpit, completely integrated behind the dashboard with controls on the dashboard. It also has fully working wipers.
® Engine Rebuilt from the ground up:
* Block cleaned and honed professionally
* Deck resurfaced
* All new bearings
* All new gaskets
* New timing chain set
* New push rods
* New Performance heads with bigger valves: Int.: 1.94”, Exh.: 1.60”
* New Oil pump: Melling high volume
* New Camshaft: Trickflow stage 1:
Duration @ .050” 221 Int./225 Exh.
Cam lift (Int./Exh.): .312”/.319”
Valve lift with 1.6 rockers (Int./Exh.): .499”/.510”
Lobe separation: 112 deg.
* New Edelbrock intake manifold: #2121
* New Edelbrock carburetor: 600 CFM - #1405 Tuned with new jets and rods for maximum output
* New 3/8” aluminum roller rocker arms, 1.6 Ratio
* New Ford Cobra valve covers
* New HEI distributor
* New MAC equal length headers
* New 9 quart Canton oil pan with baffles.
The car has been completely setup: corner weighted and full suspension geometry adjusted.
The Cobra runs incredibly well. Nothing to do to it. Come and drive it.
All receipts are available- a file box full of them.
Pictures: http://www.flickr.com/photos/allison...7620557458337/
Price: $26,000.00
Contact: Frederic
Tel: (248) 910-8971
Email: F.Boissinot@comcast.net
