Old 09-28-2009, 05:01 PM
John-Tucson's Avatar
John-Tucson John-Tucson is offline
Hey Arthur, Both Dwight and I have the windshield center rod also. The purpose in mine is to keep the top and bottom frames of the windshield together. Mine is not attached to the body. There are about three makers of that rod, I'd suggest that you attend a few Cobra get togethers and look for that rod and see how they are attached. Some are attached to the dash frame underneath the body, some are either screwed into the fiberglass or bolted from underneath. If you look at the bottom center of your windshield frame you'll see two very small holes, some makers use those holes to mount a piece of flat stock to the frame there and attach the rod to that flat stock. It can be a difficult project to do after you have the body on and painted.
John
