  #35 (permalink)
Old 09-28-2009, 10:09 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
1/4" rod may be fine to hold the windscreen in compression, but it would not be great for the triangulation that I want to do. I'm starting with 1/2" as the test. Later I'll machine the shaft down after I've located the mirror at the optimum height for me. Then I can see what minimum diameter shaft will finally work. For now the plan in in the works.
I don't think that a 1/2" shaft will block the visuals too much. But we'll see.
Arthur
