Old 09-30-2009, 08:50 PM
Stentor's Avatar
Stentor Stentor is offline
Cobra Make, Engine: CSX 4000; Shelby aluminum FE with 58mm IDAs
Originally Posted by Full Throttle Al View Post
I posted this in the other Weber threads but wanted to make sure you saw it, my reply from Berg:
Mr. Sorkey, Our Berg IDA carbs have the same stud pattern as the original Weber 48 IDA. The top of the intake manifold needs to be opened up for the larger throttle plate in our carbs.
Sincerely,
GENE BERG ENTERPRISES
Tim Walker
Parts Manager
Al,
Thanks for posting the message from Berg. I have confirmed that the standard 48 IDA FE manifold will work just fine (consistent with the message you received). I have already had the machine work done on the manifold to match the Berg 58 mm carbs.
Thanks for the heads-up regarding the hood scoop. I went with the shorter velocity stacks to try to help with hood clearance. However, the diameter of the stacks is almost 4" at the top--so they're pretty wide.
I will keep you posted as I try to get things together over the next couple of weeks.
Thanks,
Stentor
