Old 12-04-2001, 07:59 PM
Cobranut Cobranut is offline
Cobra Make, Engine: Genuine original Unique MotorCars 427 S/C, with a Genuine original Ford 427 Side-oiler.
Send a message via Yahoo to Cobranut
Default It works...sort of.
Well, I got everything back together today.
I fired her up on the lift, and stuck it in gear.
The clutch won't quite release completely, it drags just enough to keep the trans spinning, making reverse grind a bit.
I adjusted the slave pushrod for about .100" clearance, and lengthened the pedal pushrod to maximum, but it still drags.
However, the pedal pressure is very light, heck I can push it down easily with one hand now.
I just ordered a 1" bore master cylinder to replace the 3/4" unit.
I hope that will firm up the pedal and shorten the throw back to where it was before.
Later,
David
