Old 10-01-2009, 05:52 PM
Larry N Johnson's Avatar
Larry N Johnson Larry N Johnson is offline
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
Default Wheel Machining
Originally Posted by LMH View Post
I don't doubt you that one wheel fits on another adapter. You're dealing with a standard bolt circle of 5 X 4.5" and pin diamaters the same size. My issue comes in with the angle inside the wheel, the angle on the adapter and the angle on the spinner all mating up.
If both Vintage and Trigo have all those in the same place, then they are truly interchangable. If they don't, then they aren't.
Larry,
I understand what you are saying, but is it not true that the wheels seat on the face of the rotor, not the angle? If that is true, then the wheels must be machined enough to clear the angles, not touch at all. Therefore the angle height and the angle itself do not matter as long as it clears the wheel.
Are we on the same page yet?
