Old 10-01-2009, 07:24 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
The bearing that is marked "BAD" is used as a tool. The OD is ground down a few thousandths of an inch so it slides right into the upright without having to be press fit. The ID is also ground so the hub can slide through it. That way we don't have to press everything together to check the clearances.
