Old 10-01-2009, 09:35 PM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
Originally Posted by cobred View Post
If you have a clicking sound there is something wrong with your car, not the design of the system. Most likely from the pad tabs not being bent over as stated in this thread and or from too rough a rotor finish.
I beg to differ. The clicking of the Chevrolet brakes is a well-known problem, and, as I wrote earlier, you have to do a hokey tweek to silence them. Even with the ears pinched down correctly as I had done, the pads shift from pin to pin as you rotate the wheel back and forth.
Most people probably wouldn't even notice it, but certain noises make my skin crawl. It was either get a louder engine or swap the Camaro calipers out.
I've looked at them a great deal, on and off the car. Tighter tolerances would have corrected the problem.
DD
Dangerous Doug
"You're kidding, right?"
