Old 12-05-2001, 06:02 AM
Cobra20646 Cobra20646 is offline
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
David,
A couple things to check first.... if you haven't already done it.
First would be a compatability issue between the present master and slave. If the present master is moving enough fluid to move the slave to its maximum travel, your not going to gain a thing by changing masters, except maybe to change pedal feel.
If the slave is moving as far as it can before blowing out the seals, than your going to have to look at the leverage issue at the clutch fork/slave rod junction. Can you attach the rod closer to the bell housing? This would provide less leverage equaling more travel at the throw out bearing, and will also increase pedal feel.
- Jim -
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
