Old 10-04-2009, 07:26 AM
RonNichols's Avatar
RonNichols RonNichols is offline
Cobra Make, Engine: SPF398/460ci/ 144hp of backfiring fury
I had the same issues on my car after a big brake install, and went through the same shakedowns also. When I grabbed a light and compared both calipers carefully, I had installed and centered one caliper with one less shim on the bottom than the top. This was all it took to pull to the right(right caliper cocked). It still pulled a little after the fix until I rebedded the brakes.
Hope this helps.
R
