Thread: Front End Shake
Old 10-04-2009, 08:52 PM
Danr55's Avatar
Danr55 Danr55 is offline
I used a spring gauge. It's the same one I use for setting drag on fishing reels. Made a loop out of safety wire and hooked it over the tie rod end. Adjusted until I had 16 pounds required to pull the rod end down or up or laterally. Then grab the tie rod end and make sure you have a full range of motion in all directions.
Dan in Arizona
CCX3209
