Thread: Broken Lifter
Old 10-04-2009, 10:37 PM
onefastmustang's Avatar
onefastmustang onefastmustang is offline
Cobra Make, Engine: CRII with a Stroked Windsor
Originally Posted by 4pipes View Post
Considering that the major load is forcing the roller up into the body, I would guess that the press fit of the shaft into the body was excessive, and as a result left a microscopic crack at the time of assembly. The crack propagated under stress (vertical vibration).
So you are thinking they were just a defective set?
I checked my valve springs and they are the X302 set that Ford states is compatible with roller camshafts so I don't think there is an issue there. I am wondering if the spider is creating an issue. One of the dogbones was a little loose. However the lifter under that dogbone was actually fine. I guess I will wait and see what KC has to say.
