Thread: Broken Lifter
Old 10-05-2009, 07:41 PM
DAVID GAGNARD's Avatar
Originally Posted by olddog View Post
I'm no expert. Well let's put it this way. I don't get bothered at night by a phone ringing off the wall with people offering me big bucks to work in their engine shop. With that said here is my logic on the lifters. When the cam is pushing up on the lifter's roller and the pushrod is pushing down on the top of the lifter (via spring pressure), the forces on the roller pin are exactly the opposite of the piece that broke off.
Unless the roller pin is bent, excessive spring pressure is not going to cause this. If the pin flexed and did not yield (spings back to straight) it might cause this, but as small as these parts are I just wouldn't think this could happen to good parts at any reasonable spring loads. I would think that type of spring pressure would collapse the lifter.
Since I cannot think of anything, other than flexing or bending of the roller pin. that would put a force in the direction needed to cause this break. I am thinking sub standard material or machine work. I would blame the lifter until something else is proven to have caused this.
I'm certainly no engineer, but since the camshaft is turned by the timing chain, turned by the crankshaft, I would think more pressure could be put on the lifter/pushrod/rocker arm than the opposing spring pressure,causing two different amounts of pressure against the pin/roller of the lifter...I would also guess the roller pin is made of some serouis material, and the outside of the lifter (broken piece) that holds the pin in place would be the "weak link" here....the lifter could/would collaspe till it bottoms out and acts as a solid lifter, then there is no "give".
It's possible, might be a stretch, but possible.. I agree, probably a bad lifter, but given those Ford lifters are used in some serouis motors, it's rare to see them fail the way this one did.....Could be some other unkown "thing" contributed to the lifters failure. I wonder what the camshaft lobe looked like????
David
DAVID GAGNARD
