Old 10-06-2009, 07:52 AM
dcdoug's Avatar
dcdoug dcdoug is offline
Using washers (even splits) defeats the purpose because the serrated head will hold the bolt to the washer but allow the washer to relax against the pan.
It is best to shorten the bolts. Run them through a die to get clean threads and let them bite the pan directly. It's a PIA because there are 22 of them (I think) but with a sharp hacksaw blade or a cutoff wheel it's really worth doing. Don't forget to start a nut on the threads before you cut to length, then remove the nut to chase the thread a little.
Thanks for the good advice! Will do.
www.partskeeper.com
