Old 10-09-2009, 08:55 AM
Argess Argess is offline
It's quite easy.....not quite 4 bolts though. You also need to disconnect the rear brake line, emergency brake and 4 bolts from the driveshaft.
What's tricky, is having the car high enough up that you can pull the cage out from under the car. And you need one of those motorcycle/ride-on lawnmower/ATV jacks to hold the weight of the whole rear suspension and lower it down.
I put mine in before the body was on and before the gas tank was in, and that made it pretty easy. But not quick.
