Old 10-09-2009, 10:00 AM
Argess Argess is offline
Thus the term "cage fighting." He's also gone on record as saying the unsprung weight of the Jag and ERA rear are pretty much the same. I believe him on this latter point.
I would believe him too. A fine fellow, Bob P is. But it may be a matter of number manipulation. If you do it as a percentage, everything is much closer if in both cases, you add the weight of a wheel and tire into the equation. Mind you, how many Cobra owners drive over rough roads or worse, drive it hard over rough roads, so unsprng weight is probably a non-issue anyway.
