Old 10-09-2009, 11:55 AM
dcdoug's Avatar
dcdoug dcdoug is offline
Originally Posted by Argess View Post
The body is too low to use ramps, plus ramps slip on concrete so I'd have to do it outside,....where things get lost and hyd jacks for raising the other end can sink into the grass or dirt and tip over.
Raceramps with extenders would work, although they are not cheap.
http://www.raceramps.com/xtenders.html
I don't think they'd slide much either with the extenders on them as the incline isn't very steep and once the car is up, you can remove the extension to make it easier to get under the car. And if they did slide, I have seen people take a 1x4 and tie it to the ramp so when they drive the car onto the board it keeps the ramp from slipping.
Doug
www.partskeeper.com
