This is a Crank Trigger, absolutely dead nuts accurate. It does not provide for any advancing of the ignition timing based upon RPM. It fires at the same instant each time. To change when it fires with relation to crank rotation the "Pickup" is moved in a slot on its mount to a slightly different location around the perimeter of the Trigger Wheel (just a few degrees).
http://www.msdignition.com/info.aspx...=32&taxid2=447
Rick
