Old 12-06-2001, 01:03 PM
jdean's Avatar
jdean jdean is offline
Neutral
Default My 460
460 built primarily for street cruising, backed up by a C6 with 3.08 rear gears.
Complete, but on the engine stand ready to be put in.
Edelbrock Torker II (for hood clearance, otherwise might use Weiand Stealth)
Edelbrock 800 CFM vacuum secondary carb.
2.19/1.76 valves. 218/228 cam. Roller rockers. 9.4 CR Speed-Pro hyperuetectic pistons .030 over with coated skirts.
Stock heads machined for larger valves, mild port work and milled .010, Block was decked .030 as well for tight quench area. Supposedly good for an extra 20-30 horses if quench is .030-.040 range.
Haven't had it dyno'd yet, but Desktop Dyno says 469 HP, 510 ft. lbs. I would be happy if it is close to that.
