Old 10-13-2009, 05:00 PM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
Originally Posted by fkemmerer View Post
On you problems with the AN lines, suggest you get a set of Kool Tools assembly aides and a hose cutter. These two tools helped my results a lot and sped things up considerably.
I thought I'd make the investment in some of the helper tools. I have a whole truckload of lines to make for the Mustang and would prefer not to job out the task, nor waste any more line (6AN, fortunately) in larnin'.
Just a suggestion if you decide to try bypassing your cooler - you'll need to do this inside the engine bay with a new line.
Even easier, I can just reposition one of the cooler lines, remove the second one and cap off the cooler fittings. That might be a little messy but good enough to see how much effect the cooler has or doesn't have.
= Si Opus Quadratum vis, angulos praecidere noli. =
