  #30 (permalink)
Old 10-13-2009, 05:37 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
Isn't the shock a different size (length) for the CR MII? Also there is a different spring rating for the engine type, small block vs big block.
Brodie,
I went with the ProShock coil over for a BB. I purchased thru CRII a few months before they went south. I can look up the part numbers for you if you need me to. I just have to do some digging to find them. Let me know if you want them. Although I did replace the stock upper and lower A-arms i'm pretty sure it would bolt up without a problem to the stock version.
John
