  #31 (permalink)
Old 10-14-2009, 08:39 PM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
Originally Posted by Pete Munroe View Post
The MOCAL unit IS available with a 180 temp or, 212/215 setting (for a higher price I think).
180 and 200 are what I've found, at the same price. The Canton's 215 is probably more suitable to over-cooled Cobras. That seems to be the consensus, anyway.
Cobra's tend to have some some room up front so the CANTON may be a good choice, especially if you rotate the main housing segments to your advantage, ie: shorter hose runs without too many 90 and 180 fittings
I think I can do a very clean install with almost no sharp bends by fitting the Canton to the remote oil filter bracket. One 90* bend, hardline, between the filter bracket and the Canton input, and by reshaping the other lines I can all but eliminate other bends.
I just wish the Canton came in funky 1966 finish.
= Si Opus Quadratum vis, angulos praecidere noli. =
