Old 10-16-2009, 04:20 PM
Ronbo Ronbo is offline
Cobra Make, Engine: Kirkham #570 w Shelby FE
Originally Posted by PeteF View Post
Now I'm wondering how the greaseless design can get 150,000 miles.......what magic allows that? Must be newer technology grease......thanks again to all of you for the sharing of knowledge and experience. That last photo is worth 1000 words. I assume it gave no advance warning, or you would have done something......I expected I would hear or feel something.
I think they're referring to "maintenance-free" joints, which just means the drilled grease passages (and zirk) aren't there.
It's a trade-off, the joint is stronger without the drilled passages however you also may not know when the grease has leached out either.
I've seen my share of the maintenance joints fail as well, when you pull it open (if it isn't already) one of cups is bone dry.
These cars are just hard on parts, the driveline was never designed with 600hp and a manual trans pounding the hell out of it in mind.
