Old 10-17-2009, 11:45 AM
Ronbo Ronbo is offline
Cobra Make, Engine: Kirkham #570 w Shelby FE
The joint will rip in half under this type of failure (not very common), typically one of the brearing pins has snapped off (or worn off in the case of a dry joint which is also a lot of the failures).
In the picture posted you can clearly see the snapped off pin that the bearing cup rides on.
Replace your driveshaft U-joints regularly, they're pretty cheap. Your half shafts see about 1/2 the force the driveshaft does so replace all of the joints every other time.
While you have the driveshaft off check your free-play on the pinion...
