Thread: ISIS update
  #23 (permalink)
Old 10-19-2009, 01:41 AM
Pecal Pecal is offline
Wiring pretty much finished so it was time hook it up to a battery. By leaving the fuses out of the Powercells you can check the integrity of the inputs. You can switch on each circuit via its' switch and a LED for that circuit will indicate on the Powercell if the message is getting through. Once the inputs are verified then you can insert the fuses and see if the outputs work. So far I've checked Lights, High beam, Brake lights, indicators, Ignition and Accessories. Next step is to put the dash in check the rest. It's going well so far buy I'm not naiive enough to believe there are no gremlins.
Peter
