Old 10-19-2009, 10:03 PM
Buzz's Avatar
Buzz Buzz is offline
If you hold a steady speed in a lower gear (2nd or 3rd) and suddenly lift off the throttle, does the car pull to the left? If it does then there is surely an issue with the rear suspension geometry changing due to worn or loose components. If it does not pull on sudden deceleration and only pulls on acceleration, then I would guess that it's either a problem with a defective limited slip differential or an out of spec rear tire diameter (larger diameter on the left rear).
Tropical Buzz
