Old 10-21-2009, 05:34 AM
eddytheb eddytheb is offline
The wilwood one has a different mounting bolt hole pattern and would have to be mounted sideways I use these most of the time. You would also have to use the remote reservoir. You can get a line in there using the master they call for but the bend in the line has to be right at the fitting. I use a pliers style line bending tool and it works out fine if you chose to use that master.
Stop by and see what we are working on @ www.eddytheb.com
