Old 10-21-2009, 03:54 PM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
Z, I know I can get the PCV valve hose through the pan - I will do that when I next put the pan back on. The problem is that the eeny-weeny S&H air cleaner has no room to put the fitting for the breather hose from the other cap, and I will have to have that to pass the California smog check. (I'll leave the PCV valve and hose on but go back to the open breather when I put the TP and S&H back on for show.)
Mick, I have a nice throttle bracket; what I need is the spring attachment bracket that normally is bolted on the carb stud or intake. There are a dozen to choose from at any speed shop, but I'd like to use the "right" part if anyone can tell me what Ford or Shelby part it is. (Right now, both throttle springs go to a bolt on the turkey pan.)
= Si Opus Quadratum vis, angulos praecidere noli. =
