Old 10-22-2009, 09:21 AM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Zoom
Good question, I am not running a stand alone pres reg, I am running a deadheaded no-return, Edelbrock external pump that is internally regulated to 6.5 psi (it actually has a fine adjustment screw if needed), I am measuring about 6.00-6.25psi at the carb. I realize there are some pressure pulses in the fuel line that the gauge needle must dampen, but a good gauge will dampen these pulses, my Moroso gauge did for about 40 minutes.
Your regulator is dampening these pulses so your needle is more stable perhaps. Thx
Bill
"...some assembly required, ages 8 and up...... well that took longer than expected......
