Thread: On the scales
  #21 (permalink)
Old 10-22-2009, 08:40 PM
289fia_cobra's Avatar
289fia_cobra 289fia_cobra is offline
I had the same issue too... off throttle it's pull a little, hit the gas, it'd do the same thing.
I took mine to Custom Alignment in Mountain View, CA (a bit too far for you) and funny thing was, where I had adjusted my coil overs was pretty damn close to what they finalized it at. And then they said: "the dartyness was from your tire pressures; none of the tires were the same psi. they ranged from 19psi to 27psi." They put them all at 28psi and the car was fine all around!
Recently, I started feeling that dartyness again; refilled the tires to equal pressures... bingo!
Check your tire pressure before and after alignment and weight balance.
My Build Site
