  #21 (permalink)
Old 10-23-2009, 06:21 PM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Ref info
Jim, Here is some ref info when you put it back together. The crush sleeve is set (collapsed) using a torque to turn figure in the 10-30 inch pounds range depending on new or used bearings. I have never set up one with the solid sleeve , but I am sure someone here on CC has. good luck
http://www.richmondgear.com/ringandpinion.pdf
"...some assembly required, ages 8 and up...... well that took longer than expected......
