Thread: On the scales
Old 10-23-2009, 09:48 PM
lloyds1 lloyds1 is offline
Cobra Make, Engine: SPF 02345, Roush/Yates 358 Sprint Cup motor
Dennis Olthoff told me to run my TD's at 18psi, it seemed to make the car more compliant than running them at the higher tire pressure.
Also, remember that race tires need to get up to temperature before handling correctly.
Also, the fact that the north east has some pretty rutted out roads doesn't help either.
Originally Posted by dcdoug View Post
My tire pressures are the same all around - about 26 psi, which was where the Ford dealer had set them that did the alignment. Will more psi or less psi increase the wandering/darting, or does that not really impact it specifically?
