Old 10-24-2009, 08:12 AM
Gatorac's Avatar
Gatorac Gatorac is offline
Cobra Make, Engine: BDR 930, 427 Windsor T56
Next question..... I set the backlash and pinion depth. I've got a real good pattern. Now on to set the carrier bearing preload. I set the preload with the caps at 20ft/lb. Then when I torque the caps to the required 75ft/lbs, the resistance or preload increases dramatically. 19in/lbs -35in/lbs. I haven't read anything about checking the preload with the caps at full torque. Am I being concerned over nothing?
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
