Old 10-24-2009, 04:11 PM
patrickt patrickt is offline
Originally Posted by Ralphy View Post
patrickt,
I plan to add an oil accumilator, I think any motor can benefit. I have not decided if I will buy a 2 or 3 qt. unit.
I will be using Shell Rotellla, if a 22 to 1 compression ratio motor uses it, seems good to me.
http://www.summitracing.com/parts/CTR-24-006/#
Rick Lake swears by an accusump. I think he's told me that it has saved his engine at least once, maybe twice. And that's in addition to the pre-pressurizing before you start it up after it has sat for a while. On the first start up of the spring, after my engine has been sitting still for 5 months, I crank the engine with the ignition disabled until I get a little pressure, and then I fire it up. My thinking is that if I only do that once a year I doubt it's adding much wear, and I'll consider myself really, really lucky if I get to do it 25 times.
