Old 10-26-2009, 03:47 PM
RedBarchetta RedBarchetta is offline
Banned
Originally Posted by lineslinger View Post
Is there a reason you couldn't put a sandwich style thermostat of this configuration in line? This one only opens (to the cooler) if the oil temp. exceeds 220 degrees.
Aside from blowing 3/4 qt of cold oil (from the cooler and lines) into a hot engine, I can't think of any reason not to do that.
That's the beauty of either Rob's design or the Canton T-stat...both have the ability to trickle oil thru the cooler at all times so the above scenario never occurs (the Canton flows 90/10 until ~210*).
-Dean
