Old 10-27-2009, 01:55 PM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Thumbs up Hose Connectors with Bung installed
I ran accross a supplier that makes various size Brass radiator/coolant hose connectors with a brazed 1/8 NPT bung. Handy if you want to mount a temp sender/bleed valve, thermocouple etc. in-line. The supplier is called Temprel Inc. out of Michigan. Available in a range of diameters they quoted about $24 delivered each. http://www.temprel.com/mounting-hardware--fittings-22/
"...some assembly required, ages 8 and up...... well that took longer than expected......
