  #38 (permalink)
Old 10-29-2009, 03:28 PM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
Originally Posted by fastd View Post
New related question:
Are we overthinking/oversolving all of this?
If my oil shows 60-70 C in the pan; that means it is hotter coming out of the block, guessing 70-80 C; and in the hottest parts of the engine (bearings, around the pistons, etc), it is probably still hotter, guessing 90-100 C (although I read an article that said the temp difference is actually greater); doesn't that make 60 C in the pan OK if I can keep it there?
I think maybe YOU'RE overthinking this. I doubt there's much temperature variance anywhere in the liquid oil once an engine is warmed up. The film on the walls of the cylinders, etc. might be hotter but I'd bet that if you had sensors in every part of the liquid, it would be within a degree or two. (The downstream line from the cooler being the exception.)
The magic 80* is the point at which oil cooks off moisture and vaporizes it, meaning it can be removed by exiting the breather or (better) being pulled out by the PCV system. Any lower and the vaporization will not be as complete.
= Si Opus Quadratum vis, angulos praecidere noli. =
