Old 10-30-2009, 12:34 PM
07cob's Avatar
07cob 07cob is offline
Default R32 rear
Greg
My 16" rear wheels have 125mm front offset and they sit well inside the guards with the standard R32 rear. Is yours an R32 or R33 rear?
With the standard upper arms on my R32 rear, the adjustment wouldn't let me get more than about -2.5 degrees of camber. The standard adjustment provided little help - as you have discovered. In the end I fitted the aftermarket adjustment kit (both upper arms on each side) and have been very happy so far. If you want to have a look on your way back from seeing Spook, just let me know - I should be around after lunch. I'll PM you my number.
Good luck
Geof
