Old 10-31-2009, 07:45 AM
mikeforte mikeforte is offline
Hi Tim,
Your gear ratio could work with the TKO-600 .64. It really depends on your cam profile. The gear ratio with be about 67 mph in 4th gear. When you shift into 5th the rpm will drop to 1920 at the same speed. The .82 would be 2480... It depends on what speed on the highway and cam profile.
If you have any questions, feel free to call me weekends 781 248 8946 or weekdays 508 875 0016.
I stock all the TKO models and could supply you with all related parts to assemble the driveline. You could also use the T-56 Magnum and have the best of both transmissions with 2 overdrives....
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
