Hi,
The T-56 pictured above is the Tremec 1386-012 which is now a discontinued part number. The Ford version of the same T-56 is limited in avalability but still available. The T-56 Magnum is the replacement and is much stronger and has a 26 spline input shaft. Quick Time does make a scattershield.
The T-56 Magnum has a midshifter option and the rear shifter can be unbolted and ratated 180 degrees to move the shifter location forward.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
