Keep it simple.. Fuel, Air, Fire..
She's getting air..
Have you pulled a plug to see if you're getting fire?
Was it running good before you parked it?
Check and double check your plug wires.
Timing, are you sure you're not 180 degrees out?
The EFI is pretty bullet proof and it will fire, even if the timing is off a bit.
If the car was running before you changed the intake and now it doesn't, focus on things that you touched when switching the intake.
Joe - -
FFR MKIII Roadster #5392
