Old 11-02-2009, 06:53 AM
Snakebit's Avatar
Snakebit Snakebit is offline
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
Am I missing something here? I thought the regulator had to be mounted between the fuel pump and the carbs, and as close to the carbs as possible. The guage can be mounted after the carbs. If you mount the regulator after the carbs, then how can you adjust the fuel pressure?
The fuel pressure regulator is there to regulate the fuel pressure to the carbs, just under 3 lbs for Webers. You need a return line so the excess pressure can be bypassed.
Snakebit
