Old 11-02-2009, 04:37 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
The pink cams , 30cc pumps and 031 squirters work pretty good on most all demon setups---you might try leaning the primary jets 2 numbers, putting in a 4.5 power valve and setting the butterflies where you just barely have the transfer slots open and then adjust the idle eze screw for an 850 rpm idle with the idle mixture screws about 3/4 to 1 turn open but not past 1 1/4 turn
