Old 11-03-2009, 06:53 PM
springin springin is offline
Cobra Make, Engine: AddVintage, 351C
Default No, not like that but close.
Not sure what I have run across now. The nut was the same size as the pipe and the washer under it. Since the nut was loose I suspect it was causing my cooler adaptor to not seat all the way..... I went to two speed shops and talked to three Ford Pros and they had never seen such a set up. I have since removed the nut and washer and installed a short filter. Seems to be just fine..... Thanks everyone....
