  #27 (permalink)
Old 11-04-2009, 07:36 AM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by DAVID GAGNARD View Post
Very simple, you know your tire size and rear end gear ratio, you need to "plug in" these numbers into anyone one of the many gear calculators and see what your rpms will be at any given speed......
You also need to know what your engine torque range will be, as stated, don't worry about your peak hp #'s, worry about your engines torque band and try to get your rpms into the torque band..........
David
Here's a link to the calculator on Second Strike.
http://www.secondstrike.com/Technical/GearCalc.asp
Doug
