Old 11-06-2009, 03:53 AM
Mando's Avatar
Mando Mando is offline
Hi Mike, car was started last week. The tuner spent about 1/2 an hour trying to get some oil pressure and in the end removed the sender and attached a mechanical pressure gauge and all was good. An hour later it was breathing fire. It's tuned to about 4000rpm and has about 115 hp at this stage. Just enough to meet ADR's. The numbers seem to meet requirements at the moment but it sounds louder than I thought it would be, but we still need to check it with a meter.
It's off to the painter tomorrow and hope to get it back in 6-7 weeks.
Buy the way, I installed the arms you made for me after I got them back from the painter and had a wheel alignment a couple of weeks ago. The guy said everything was spot on. Thanks again for all the work you put into getting the arms right, they fitted perfectly and look great.
Regards.
Mando
